Bulk temperature Tf is obtained from total or static temperature?
Old   March 30, 2011, 05:56
Question Bulk temperature Tf is obtained from total or static temperature?
NPU_conanxie is on a distinguished road
Hi, how are you? I have a question for your help.
Assume compressible idea-gas coolant flows into heated channel like turbine blade internal channel. BC: walls are given constant heat flux, inlet is given mass flow and total temperature, outlet is given pressure. Now I want to obtain the heat transfer coefficient, h=q/(Tw-Tf).
Generally the bulk temperature,Tf, is simply averaged by inlet and outlet temperature. Now, I just want to know, do the inlet and outlet temperature be referred to total temperature or static temperature? Or, Tf is averaged by inlet static temperature and outlet total temperature ?
Wall temperature,Tw refer to static temperature? If I choose static, the some of Tw are lower than the Tf.
Please help me charify the problems. Thank you.
NPU_conanxie is offline   Reply With Quote
static temperature and total temperature showwa FLUENT 3 March 24, 2016 05:58
static temperature is higher than total temp. in buoyancy problem amirbahador FLUENT 2 October 24, 2010 07:21
Total temperature and static temperature rogbrito CFX 1 June 21, 2009 18:37
Static and Total Temperature Tomislav FLUENT 4 December 4, 2006 04:59
The static temperature is higher than total temp devy FLUENT 0 March 27, 2003 20:16
