Boundary condition for exhaut flow with imposed mass flow
Old   April 25, 2011, 13:13
Default Boundary condition for exhaut flow with imposed mass flow
stephane is on a distinguished road
I'm modeling the ventilation of a room with Fluent. At the inlet, I would like to use a velocity inlet BC. I have several outlets. I would like to impose the mass flow at these outlets. For instance, let's say I have an inlet with a mass flow equal to 1 kg/s and 2 outlets where the mass flow are equal to respectively 0.8 kg/s and 0.2 kg/s. Which BC should I use at the outlets? Can I use some velocity inlet BC at the outlets to impose the flowrate? Or should I use some pressure outlet boundaries with the target mass flow rate option? I could also use an outflow BC and adjust the flow rate weighting. What is the best approach.
Thanks in advance,
Stéphane
stephane is offline   Reply With Quote
Old   November 24, 2011, 02:04
delaneyluke is on a distinguished road
I assume your flow might be compressible. If so, the outflow condition will not be applicable. The pressure outlet BC with target mass flow is a better option.
Oops, this is a late reply. Hope it helps.
Regards
Luke
delaneyluke is offline   Reply With Quote
atio
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
External,incompressible flow boundary condition? John FLUENT 2 August 19, 2011 00:42
outflow boundary condition foe flow over a cylinder Ardalan Main CFD Forum 0 April 29, 2010 13:04
OutletBoundary Condition Causes Mass Imbalance Andy Main CFD Forum 0 March 11, 2004 14:05
