Axysimmetric cases compare to planar case with symmetry boundary condition
Old   June 7, 2011, 07:40
Default Axysimmetric cases compare to planar case with symmetry boundary condition
hafiidz jaafar
hafiidz is on a distinguished road
Hi guys,
I am trying to run an 2D axisymmetric underexpanded jet fire using fluent. However, to simpify the case we use the pseudo diameter approach and focus just on the visible length of the flame ( the shock waves are being excluded).
I created my mesh using Gambit. setting it up to be an axisymmetric case. However, when I exported it to Fluent, I can't run it with the BC that i have set in Gambit as I can't initialize it. But when I changed it to planar cases and the axis to symmetry, it can be initialized.
I hope someone can point me what's the difference between these two settings and how can I overcome it.
Thank you.
hafiidz is offline   Reply With Quote
Old   June 8, 2011, 13:40
Casey
meangreen is on a distinguished road
A few questions:
what version of fluent are you using?
Is it a cracked version or do you have a license?
When you make your mesh in gambit to you export it as a 2D mesh?
Are you going into define-models (i think that is the way, my fluent is down for a little while) and setting the solver to axisymmetric?
meangreen is offline   Reply With Quote
Old   June 8, 2011, 17:46
xrs333
xrs333 is on a distinguished road
Hi, jaafar,
For axisymmetric model, it is necessary that the axis must be X axis and the grid above X axis.
xrs333 is offline   Reply With Quote
Old   June 9, 2011, 03:17
hafiidz jaafar
meangreen
I am using fluent 12 and 13. Both of them are with license. I exported it with 2d mesh as well. I have defined it in the general part in FLUENT.
xrs333
I see. i will try that. Anyway, is there any differences of result between axisymmetric model and setting a planar model with symmetry boundary condition.
thank you for the reply guys.
Old   June 9, 2011, 10:26
xrs333
Hi, Jaafar,
They are absolutely different.
Old   June 14, 2011, 06:29
hafiidz jaafar
Thank you for your reply.
symmetry boundary condition in fluent v_h_memar FLUENT 8 May 1, 2019 00:08
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
farfield Vs symmetry boundary condition Rajat FLUENT 1 October 21, 2005 13:53
Symmetry boundary condition Shankar FLUENT 1 August 11, 2003 15:58
