reduced version of GRI 3.0 Mechanism
Like Tree2Likes
  • 2 Post By Mica
Old   July 5, 2011, 15:20
Default reduced version of GRI 3.0 Mechanism
Sergej
buxtsued is on a distinguished road
I wish to simulate a combustion in Fluent 13.0 with the "gri 3.0"-mechanism. After importing it in chemkin format (with the appropriate thermo.dat) and setting to pdf transport model, there appears a message "Maximum of 50 solved species allowed. Use Dimension Reduction instead." (gri 3.0 has 53 spesies). I have tried to reduce the number of spesies to 50 using the "Dimension Reduction" option (choosing out varios three spesies from the list "i wish not to take part"), but it doesn't work, nevertheless. In the 'Spesies Model' dialog box the number of volumetric spesies can be seen under "reduced-dimension-mixture", which remains 53 (in spite of using the dimension reduction option).
Do anybody know how to use a 50-species (e.g. reduced) version of GRI-Mech 3.0 in Fluent???
Thanks, buxtsued
buxtsued is offline   Reply With Quote
Old   July 13, 2011, 04:41
Mica is on a distinguished road
Hey buxtsued,
I'm working with a reduced Grimech mechanism. DO the following:
Open the chemkin-file you want to import in any text-editor. You can quote out the following information in a line by "!" (As done in the header)
Quote out or delete the most abundant species. In my case these are AR C3H7 and C3H8. Remember to quote out AR in the elements list too.
Search all reactions containig these species and quote them out. You can also reorder your species and set N2 at the last place. This is appropriate for combustion in air, then you dont have to specify the fraction of N2 in Fluent, since it is just the rest.
Greetings,
mic
Mica is offline   Reply With Quote
Old   July 13, 2011, 19:47
Sergej
Hi Mica,
i have tried to do so, but there is still the same problem. Did you use the "Dimension Reduction" function after importing your modified chemkin mechanism?
Maybe i didnt modify the gri3.0-file correctly. Could you eventually send me your modified mechanism?
BR
Old   July 14, 2011, 02:49
Here it is...
Hak kim and mzubairq like this.
Old   July 14, 2011, 11:01
Sergej
It works. Thanks for your help.
Old   November 21, 2014, 09:33
Default GRI 3.0 Mechanism
Chris
dpfrz is on a distinguished road
Hey guys, its crucial that I use GRI 3.0 Mechanism for my simulations but unfortunately I think I will need a CHEMKIN-CFD license to do so in Fluent. Is there another way to do this without a license or even find the license somewhere?
Thank you for your time!
dpfrz is offline   Reply With Quote
Old   July 23, 2015, 08:19
jp279
jp279 is on a distinguished road
Send a message via Skype™ to jp279
After importing the Chemkin file for mechanism and transport, fluent takes very long for each iteration (Steady State).
Can anyone suggest any speed up criteria where I can avoid solving for a few less important species?
(Currently solving for 50 species)
jp279 is offline   Reply With Quote
Old   August 7, 2018, 09:32
Weiqiang Liu
Weiqiang Liu is on a distinguished road
hello,
is the maximum number of species imported in chemkin format is 50? because when I use GRI 2.0, simulation can proceed. however, when GRI 3.0 is used , error occurs at the beginning of calculation.
Weiqiang Liu is offline   Reply With Quote
Old   August 7, 2018, 12:53
Lucky
Originally Posted by Weiqiang Liu View Post
hello,
Yes. Fluent has a hard-coded limitation of 50 species. Someone at some point decided Fluent should never be used with more than 50 species, which is really annoying considering GRI 3.0 is 53 species. Fluent comes with a 50 species version of GRI 3.0 (AR, C3H8, and C3H7 radical are removed) if you need it.
Old   August 7, 2018, 14:32
Weiqiang Liu
yes, it's really annoying. do you know any other tools or codes that can simulate combustion with mechanism more than 50 species?
Old   August 7, 2018, 14:36
Lucky
I only one I have experience with is Star-CCM. OpenFOAM has this capability too, but I haven't used it. But can't you just use the 50species version of gri 3.0? I don't think it's worth learning an entirely new software if that is the only reason.
Old   August 7, 2018, 14:50
Weiqiang Liu
[QUOTE=LuckyTran;701840]I only one I have experience with is Star-CCM. OpenFOAM has this capability too, but I haven't used it. But can't you just use the 50species version of gri 3.0? I don't think it's worth learning an entirely new software if that is the only reason.[/QU
because I wanna simulate diesel combustion which is more complicated than methane. therefore, I wanna use chemkin or some other code which is more efficient for combustion simulation.
Reduced mechanism for Ethylene Combustion Chaitanya FLUENT 1 May 9, 2011 06:40
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 20:55
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
CARM as reduced mechanism in Fluent Adrian FLUENT 7 August 30, 2007 15:16
