ideal or non-ideal equation of state
Old   July 13, 2011, 07:09
Default ideal or non-ideal equation of state
Navid Sharifi
n.sharifi is on a distinguished road
hello
I'm trying to use an equation of state (EOS) for a real gas with density based method for an inviscid compressible flow in a con-div nozzle.
firstly I tried to use a simple revision of real gas EOS (P = Ro*R*T) and wrote a UDF with define_property macro hooked to density in material panel.
when i run the UDF, the contour of static and total pressure will be the same.
it should be noted there is an other define_property macro hooked to sound-velocity but it has no influence on the solving procedure. because if the sound-velocity is set constant there is no differende between the solutions.
I think if we want to use a non-ideal EOS it is not sufficient to write a UDF just manipulate the density in material panel.
can any body help me
n.sharifi is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
