Single Droplet_VOF ANSYS 13
Old   July 19, 2011, 14:14
Default Single Droplet_VOF ANSYS 13
Mrt
MDinc is on a distinguished road
Hello Everyone,
I am modeling a 2D single droplet impingement to a liquid film thickness using VOF. I defined the model BCs as: Rectangular domain; bottom (ground) surface is Wall, left&right surfaces are also Wall and top surface is Pressure Outlet.
I have some questions about the model choice and also solution procedure:
1.) I started simulation of the model and once I started transient simulation, I got this error message:
Divergence detected in AMG solver: pressure coupled -> Decreasing coarsening group size!
# Divergence detected in AMG solver: pressure coupled -> Increasing relaxation sweeps!
# Divergence detected in AMG solver: pressure coupled -> Changing to W-cycle!
Then, I tried different solution method and parameters. This time I got this error message:
Error: Global courant number is greater than 250.00 The
velocity field is probably diverging. Please check the solution
and reduce the time-step if necessary.
I also tried DPM (single droplet particle tracking) + VOF (Hot liquid film thickness). I got same error messages during iterations. Thus, how can I solve these problems?
2.) For future simulations, I also want to include droplet collisions and particle-wall collisions. Thus, can I use eulerian based DDPM+VOF models instead of DPM+VOF in order to simulate single and/or multiple droplets impinging on a thin liquid film?
3.) Maybe, I should have asked this question before: Which model is the best for the following situations?
-Single Droplet impinging on thin liquid film (With/without heat transfer and phase change mechanisms, and bubble dynamics)
-Multiple (train) droplets in a single and multiple lanes impinging on thin liquid film (with/without heat transfer and phase change mechanisms and bubble dynamics)
-Spray modeling to include droplets leaving a nozzle then impinging on thin liquid film (heat transfer and phase change mechanisms included)
Regards.
MDinc is offline   Reply With Quote
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
Any other way of converting a multi part to a single part avoiding ANSYS Design Model LusoMundo ANSYS Meshing & Geometry 1 May 14, 2009 14:35
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
P4 1.5 or Dual P3 800EB on Gibabyte board Danial FLUENT 4 September 12, 2001 11:44
