Udf for moving circular edge
Old   August 21, 2011, 08:59
Default Udf for moving circular edge
noa
anonymous
noa is on a distinguished road
I have a 2D channel that its edge is circular. I am moving the walls in y direction and this working. However, when I am not able to move the circular edge. This is the UDF I am using...
#include "udf.h"
#include "mem.h"
#include "dynamesh_tools.h"
/* Constants */
#define b 1.5e-3
#define T 20
#define a 0.0e-3
#define a1 10e-3
#define b1 0.5e-3
#define R 0.5e-3
#define phi 3.1415926535897932384626433832795
#define L 50
#define EdgeHeight 1.0e-3
DEFINE_GEOM(outlet,domain,dt,position)
Thread *tf = DT_THREAD (dt);
face_t f;
Node *node_p;
real x, y;
int n;
SET_DEFORMING_THREAD_FLAG (THREAD_T0 (tf));
begin_f_loop (f, tf)
f_node_loop (f, tf, n)
node_p = F_NODE (f, tf, n);
if (NODE_POS_NEED_UPDATE (node_p))
NODE_POS_UPDATED (node_p);
x = NODE_X (node_p);
y[0]=sqrt(fabs(pow(R,2)-pow((x-a1),2)))+(b1+CURRENT_TIME/T);
y[1]=-sqrt(fabs(pow(R,2)-pow((x-a1),2)))+(b1+CURRENT_TIME/T);
NODE_Y (node_p) = y;
end_f_loop (f, tf);
noa is offline   Reply With Quote
Old   August 21, 2011, 09:45
Amir's Avatar
Amir
Amir is on a distinguished road
Hi noa,
there are some inconsistencies in your code! maybe you mean:
real x, y[2];
y[0]=...;
y[1]=...;
NODE_Y (node_p) = y;// you have to assign it with a scalar not vector, y[0] or y[1]
Amir
Amir is offline   Reply With Quote
Old   August 23, 2011, 09:24
Default More help....
noa
anonymous
Hi Amir,
Thank you very much for your help.
My model is built from half circle at its edge. every x has two y values.
However, when I change my udf and define y as vector, its not working since Node_y gets scalar only.
#include "udf.h"
#include "mem.h"
/* Constants */
#define b 0
#define T 20
#define a 0.0e-3
#define a1 10e-3
#define b1 0.5e-3
#define R 0.5e-3
#define L 50
face_t f;
Node *node_p;
real x, y[2];
int n;
NODE_Y (node_p) = y[0];
end_f_loop (f, tf);
Thank you
Old   August 23, 2011, 09:46
Amir's Avatar
Amir
you can use a if-clause or a compatible statement like this:
real y;
y=NODE_Y(node_p)/abs(NODE_Y(node_p))*sqrt(fabs(pow(R,2)-pow((x-a1),2)))+(b1+CURRENT_TIME/T);
Bests,
Amir
Old   August 23, 2011, 09:56
noa
anonymous
I am sorry to bug u again but still I am not sure I got it.
I wish I could use IF but in this case of the half circle I have 2 y for every x and there is not a If statement I can use.
I didn't understand why u used
y=NODE_Y(node_p)/....
Thank you
Old   August 23, 2011, 10:08
Amir's Avatar
Amir
Ok, every x has 2 y (in circular arch one + and another -) right?
so you can use if clause (if y>0 then ... else ....)
Or, because the difference is just in a negative mark use such compatible mode.
Amir
Old   August 24, 2011, 01:23
noa
anonymous
Hi Amir,
Thank you for your respond.
I can't use If statement since that half circle is not located on the X axis, its moving along the Y axis.
Thank you,
sarit
Old   August 24, 2011, 03:12
Amir's Avatar
Amir
Originally Posted by noa View Post
Hi Amir,
Thank you,
sarit
Dear noa,
It doesn't matter; I just wanted to show the procedure; you can use both methods in this case as well. Here you have to know movement of the interface between 2 y. Suppose the interface moves with this function f(t); then you can substitute this instead of 0 in if-clause. Anyway, if you can post your geometry and your desired moving function, I may help you better.
Bests,
Amir
Old   August 24, 2011, 04:55
noa
anonymous
Hi Amir,
My files are attached.
Thank you for your help,
sarit
Old   August 24, 2011, 06:33
Amir's Avatar
Amir
Why don't you separate your outlet and define 2 macro for each(upper_outlet and lower_outlet)? in this case each x has only one y?
Amir
Old   August 24, 2011, 07:00
noa
anonymous
I tried to do that, but than I get that the parts don't connect smoothly, even when the mesh is denser.
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
velocity profile UDF on porous jump edge mani1455 Fluent UDF and Scheme Programming 5 February 21, 2015 05:31
calculating cell edge length in 2D and call UDM into other udf code pibea Fluent UDF and Scheme Programming 0 November 30, 2014 05:27
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
