Sequential solution of conservation equations |
August 30, 2011, 16:01 |
N/A
I am currently working on an internal flow, conjugate heat transfer problem utilizing a UDF to vary the inlet velocity until a certain per-determined target is achieved. I am interested in knowing if there is a way to suspend the solution of the energy equation until the UDF has determined the required inlet velocity and (maybe) the continuity and momentum equations have converged or are close to convergence. I know this can be done manually by stopping the solver and enabling the energy equation, but I want the process to be automated as I have to solve a DOE with a large number of design points. Thanks. Regards, John |
fluent, solvers, udf |
About the solution of a simplified two-phase model | maximus | Main CFD Forum | 3 | October 25, 2005 12:03 |
Sequential calculation of Temperature and mass tra | J.W.Ryu | FLUENT | 7 | June 18, 2002 07:12 |
multigrid solution of 2d euler equations | jim | Main CFD Forum | 2 | May 21, 2002 04:05 |
Numerical Conservation equations for salt content | Kourosh Hejazi | Main CFD Forum | 0 | February 26, 2002 09:11 |
CONSERVATION EQUATIONS IN NONINERTIAL SYSTEM!!! | zhang zhanwang | Main CFD Forum | 0 | August 17, 1998 07:38 |
