August 31, 2011, 20:55 |
External inviscid flow
Lyla Loco
Hi;
I modeled inviscid incompressible external flow around a cylinder with symmetric BC but the velocity or pressure field are not symmetric despite of good convergence. Any idea is appriciated. LL Last edited by lloco; August 31, 2011 at 23:38. |
August 31, 2011, 23:06 |
Stuart Buckingham
Rep Power: 26 |
What did you do with the viscous terms? An inviscid (Stokes Flow) solution should be symmetric as Re = 0.
Also, define "good" convergence. Floating point error may also make solutions look different to what you might have expected, but not by much. |
August 31, 2011, 23:35 |
Lyla Loco
Thanks ! I used the inviscid option of Fluent. The simulation converged for residuals as small as 1.e-7 but the solution was considerably asymmetric (?) with some recirculation behind the sphere.
Later I changed the pressure discritization from Standard to PRESTO and got much better results. Still not quite symmetric but much better than standard discritization. You may take a look. Btw, I am solving the Eulair equation (viscosity=0) rather than Stokes flow(viscosity=infinity). In the Eulair equation, the pressure and velocity components all must be symmetric (v is anti-symmetric) at the both side of the cylinder. The Same for velocity components in Stokes flow. But pressure contours must be asymmetric in the Stokes flow ! |
Domain for external flow | chinc | Main CFD Forum | 2 | August 8, 2010 01:23 |
What solver to use for inviscid flow simulation over missile | mecbe2002 | OpenFOAM | 0 | April 27, 2010 11:10 |
Convergence for inviscid flow over sylinder | Rjakk | Main CFD Forum | 2 | March 21, 2007 10:53 |
2D cylinder, external, laminar and turbulent flow | Dave | FLUENT | 0 | December 6, 2006 20:42 |
External flow field. | Moon | FLUENT | 3 | March 5, 2003 10:32 |
