Converting the domain to polyhedra problem?
Old   September 5, 2011, 19:48
Default Converting the domain to polyhedra problem?
Skywalker is on a distinguished road
Hi there,
I am a new Ansys user...I generated the mesh (about 6,000,000 of elements) with ICEM and I eventually exported it to FLUENT...Then I tried to convert the domain to polyhedra however my laptop grot frozen meanwhile the polyhedra cells are being built (says after one hour and an half).
Do I have generated meshes too coarse (min orthogonal quality: 0.32 and medium quality: 0.71) or there may be another reason? Is there anything I can do to improve the process? ( I already set the parallel modality)
Also: in a prevows attempt I get that I did not set the polyhedra feature angle, but how can I actually set it?
Many thanks
Skywalker is offline   Reply With Quote
Old   September 8, 2011, 12:11
Ronald A. Lau
ronaldalau is on a distinguished road
Send a message via Skype™ to ronaldalau
Originally Posted by Skywalker View Post
Hi there,
Many thanks
Sounds like your laptop doesn't have enough RAM or swap space. Try it on a PC with more RAM.
ronaldalau is offline   Reply With Quote
Old   September 9, 2011, 10:00
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
So,
you build 6.0 Mil mesh?!?!?!?!?
That's good and do not need to wonder why it is so slow.... Everything is OK!
Fluent has a good feature - if it can not handle the process it complains... so, you just need to wait.... if the RAM is not enough then Fluent will tell you this. Thy to reduce the mesh if it is possible.
Philipov is offline   Reply With Quote
Material identification between a flow domain and a porous domain Ervideiro CFX 1 June 1, 2010 09:50
[Commercial meshers] Problem converting gambit mesh to foam quartzian OpenFOAM Meshing & Mesh Conversion 1 September 29, 2008 18:29
[Gmsh] Converting curved surfaces problem markdowlinguk OpenFOAM Meshing & Mesh Conversion 4 August 2, 2007 08:05
porous domain problem sudhakar CFX 6 November 29, 2006 09:48
2d domain problem Dan Boyle FLUENT 2 March 3, 2003 08:49
