shock tube
Old   September 22, 2011, 12:50
Default shock tube
mecamor
mecamor is on a distinguished road
Hello, I am trying to model flow in a shock tube using fluent. I was able to initialize the flow by imposing initial conditions as such: at t=0, P driver= P4 (patching) with helium, Pdriven= P1 (default init)with Ar, The problem is that the results of pressure and Mach number do not agree with the analytical inviscid solution. For some odd reason, I see a sustained high mach near the diaphragm throughout the entire simulation, as a result, there are two incident shocks generated. Any one had the same problem? What is the best way to initialize the problem. Thanks
mecamor is offline   Reply With Quote
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
Shock tube simulation harish FLUENT 5 January 25, 2014 02:20
shock tube validation AB Main CFD Forum 3 December 10, 2004 07:31
shock tube validation AB Siemens 0 November 21, 2004 18:43
Shock tube problem AB Siemens 1 November 9, 2004 00:25
