No inlet and Outlet! HELP! Urgent!
Like Tree1Likes
  • 1 Post By m2montazari
Old   September 26, 2011, 13:10
Default No inlet and Outlet! HELP! Urgent!
A.A
A.A is on a distinguished road
Hi everyone.
Ok so I am modeling the semicircular canal of the inner ear which houses the endolymph fluid, maintaining the balance sense of the human body. The problem is there is NO inlet or outlet in the structure. The head movements just generate either a clockwise or anti-clockwise rotation ending up displacing an elastic material called cupula, within the canal.
1) Can I do the simulations using FLUENT, without any inlet and outlet?
2) Also, I need to show the displacement of the elastic material 'cupula( inner ear structure)'. Can I simulate this displacement using FLUENT!?
Please help me if you can! Thanks!
A.A is offline   Reply With Quote
Old   September 27, 2011, 11:17
sp
chaosh is on a distinguished road
1. You can run the problem as a closed domain problem in Fluent (define all boundaries as walls)
2. Displacement can be simulated - you will need to pick the right multiphase model for your application depending on type of flow and volume fraction
chaosh is offline   Reply With Quote
Old   September 28, 2011, 08:26
A.A
thanks a lot!
Old   September 29, 2011, 16:15
Mohammad
m2montazari is on a distinguished road
hi,
you can model the flow with no inlet and outlet, but in fluent you cant model elastic solid body. to model that you need ansys 12 or higher and you need to couple fluent (or cfx) with static structural solver. you can read more in FSI tutorial of cfx in ansys 12 or higher.
yours,
mohammad
Sai Krishna likes this.
m2montazari is offline   Reply With Quote
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
which boundary condition?pls help urgent ravish CFX 1 January 7, 2006 02:37
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
