October 10, 2011, 04:34 |
injection
leila
hi I want to introduce an injection in a chamber. in "set injection properties" it asks "Number of particle streams" what does it means? there is a spray nozzle which spray with one stream.
October 13, 2011, 10:49 |
#2 | |
Sergiu Stroe
You shout put 1 stream and you will solve the problem, because you wana single jet, right? |
October 15, 2011, 01:17 |
leila
dear sergiu
yes there is one jet. but when I enter "1" the error massage appears says: Number of Particle Streams : 1 is less than minimum. Range is 2 to 2.14748e+009 so what can I do? |
October 15, 2011, 03:10 |
leila
dear sergiu
I got it. the error is because I select the injection type as "group". but another question: I have a 2 fluid nozzle with one jet strem in my experimental setup. which of the injection type are suitable for it? |
surface injection or point injection? | sukura_1984 | FLUENT | 0 | September 2, 2009 09:26 |
Urgent help needed with spray injection | nick | Siemens | 14 | June 29, 2008 18:48 |
On DPM injection properties. | akr | FLUENT | 4 | October 23, 2006 10:54 |
DPM, UDF, Injection Type | Zhang | FLUENT | 0 | June 8, 2005 15:51 |
using injection file and parallel process | Cindy Jones | FLUENT | 0 | January 23, 2003 12:40 |
