What kind of mesh to use for cylindrical object in channel |
October 31, 2011, 21:05 |
Naser Imran Hossain
Rep Power: 14 |
Hi, I'm trying to simulate flow around a cylindrical 'Turbulence Enhancer' in a simple channel. I'm trying to mesh the faces and edges using Gambit's built in hexahedral meshing technique. However, I'd need to refine mesh around the cylinder wall to get better outputs. Can anyone suggest the steps needed to do that? Or do you guys think that I should use a different mesh type, like a tetrahedral mesh or something?
Oh, btw, it's a two dimensional problem. I've defined the cylinder as a circular object at the center of the channel by subtracting the circle from the channel face. Is that the right way of doing this? Or should I keep the circular cylinder edge intact and define it as a 'wall boundary' condition? |
November 2, 2011, 01:16 |
Maxime Perelli
Rep Power: 41 |
post pictures
In memory of my friend Hervé: CFD engineer & freerider |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
A question on adaptive remeshing or mesh deformation for handling object motions | daveatstyacht | OpenFOAM | 10 | November 13, 2010 09:29 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
