January 11, 2012, 08:24 |
Steady vs. Transient
Rep Power: 15 |
I'm modeling an explicit porous disk inside a water tank. I run a steady and transient simulations, with the only difference between them is the scheme used for each simulation, SIMPLEC for steady and PISO for transient. Results are very different!! See figures. The wake region in the transient simulation is way shorter tan for the steady simulation. Does anybody know THE WHY of this disagreement?? Fig-1: Steady simulation. FFig-2: Transient simulation. |
January 11, 2012, 14:03 |
Ryne
Rep Power: 16 |
It is my understanding that the transient case gives more of an instantaneous solution at a given time and the steady solution is given as a time averages one.
January 11, 2012, 20:36 |
Rep Power: 15 |
Rhyno466,
I think the problem was that I didn't run the transient simulation for enough time. I did so, and wake length for the transient simulation is getting similar to the steady case. |
January 13, 2012, 23:49 |
Lucky
Rep Power: 66 |
There should not be any differences between a steady and transient simulation if all else (boundary conditions, models) are the same. Since more things are likely to go wrong in a transient simulation than a steady one, most likely your transient simulation was not run properly. Keep trying.
Porous jump modelling: steady vs transient | egge24 | FLUENT | 2 | January 20, 2012 04:05 |
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 19:43 |
Mass Diffusion: Transient and Steady State BC | rval | CFX | 3 | November 19, 2008 00:52 |
Transient vs Steady State | Adam | CFX | 1 | April 12, 2007 11:34 |
Difference between steady and transient problems | Jianping Zhang | Main CFD Forum | 9 | April 14, 2003 06:17 |
