mesh quality problems: maximum skewness larger than 0.98
Like Tree1Likes
  • 1 Post By mali28
Old   January 26, 2012, 18:24
Default mesh quality problems: maximum skewness larger than 0.98
cth_yao is on a distinguished road
Hi there. I am simulating a numerical wave tank with a chamber in it. I build the mesh with DM meshing, but when I run it in FLUENT, there is a warning
maximum cell skewness exceed 0.98
what is the problem that causes the warning?
besides this warning, there are two other things, the maximum cell squish is 0.9655 and the maximum aspect ratio is 256.198
does it mean the mesh quality is low?
how can I deal with these problems?
thanks!
cth_yao is offline   Reply With Quote
Old   January 27, 2012, 05:03
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
check your mesh quality, display worst elements, and fix problems.
You need to go back on your mesher for that
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 27, 2012, 05:05
mali28 is on a distinguished road
thanks!
Mesh skewness is high if you are using unstructured mesh. But generally, it should be less than 0.85 for tetrahedral cells.
Even a few cells with high skewness can cause trouble in convergence and may even lead to divergence.
rgd likes this.
mali28 is offline   Reply With Quote
Old   January 27, 2012, 05:50
shaoda169 is on a distinguished road
Yes, you r right. Actually it is very important to pay efforts to generate 'good' mesh before iteration in FLUENT!
shaoda169 is offline   Reply With Quote
Old   May 19, 2016, 10:59
rgd
rgd is on a distinguished road
Do you have the rule of thumb for maximum skewness for all types of mesh??
rgd is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
early stall, poor convergence, and mesh quality everest CFX 2 May 12, 2010 16:27
