Fluent to OpenFOAM - good or bad?
Like Tree2Likes
  • 2 Post By -mAx-
Old   January 29, 2012, 06:24
Default Fluent to OpenFOAM - good or bad?
victorz is on a distinguished road
Hi all,
I'm relatively new to CFD, and have been using Fluent for the past few months. I'd like to consult you guys whether switching to OpenFoam as the general purpose solver is a good idea.
The geometries I will be using may be relatively complicated, with a large number of cells.
In general, I'll be dealing with incompressible flows in the following applications:
- two phase flows/condensing flows
- flows in and around heat exchangers
- heat transfer
- porous media
- flows through fans
- pipe flows
Please, write down any ideas that might be relevant, and that will help me decide whether it is a good idea (cons and pros, what questions should I ask myself before the change, what steps should I take, etc.)
Thank you very much!
victorz is offline   Reply With Quote
Old   January 30, 2012, 01:43
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
My point of view regarding incompressible flows (pipe flows >> simpleFoam solver):
We switched at the company 3 years ago (before with fluent)
pros:
*FREE!!!
*very customizable, because of open source
*full automatization possibility because of shell-scripts
*compatible with major mesher distributor (gambit for example)
*FREE!!!
*FREE!!! >> enables you to invest in the hardware instead of software
*Cons:
-Not really user-friendly, but who cares? because you can write automatization scripts, which allows you to skip the whole pre-processing
-Debugging will be tough at the beginning, but with experience it will be easier
-Post-processing (paraFoam, or ParaView) will be also disconcerting, but once you will understand how it works, you will consider it as a pros (and no more as a cons)
-no free-support, but you can get support from cfd-online community anyway
I am sure you will get more (technical-)opinions from other people
Since it is an OpenSource program, I would suggest you to test it, and to make some comparisons with models you already computed with Fluent.
trong-khoa and victorz like this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
cfd, fluent, openfoam
[Commercial meshers] Conversion Fluent cas and dat file to OpenFoam matteo_gautero OpenFOAM Meshing & Mesh Conversion 11 July 14, 2020 12:09
convertion of openfoam .msh file to fluent pankos OpenFOAM 4 December 21, 2015 12:30
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Migration from FLUENT to OpenFOAM schwarczi OpenFOAM 3 June 9, 2010 23:43
