Fluent to Tecplot - 3D slice Velocity Magnitude |
Hi
I'm currently post processing 3D case and data files in Tecplot. I am trying to get a vector plot of the Velocity magnitude on the cross section plane of the mesh. I have created a slice where I want the vector plot. When I go to select the variable to plot, it doesnt give me the option to plot Velocity Magnitude, only X Vel, Y Vel or Z Vel. Does anyone know if there is a way of fixing this? |
Just found the answer to this on a different thread on the forum (thanks fremdar!!)
I thoguht i'd post it here anyway in case anyone is having a similar problem: Export a CGNS file from Fluent (selecting velocity magnitude for me) Open the CGNS file in Tecplot using the CGNS Loader in the Tecplot 'Import' menu Last edited by emmkell; January 30, 2012 at 12:46. |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Output velocity magnitude | satellite_control | FLOW-3D | 1 | November 30, 2011 19:07 |
How to indicate velocity magnitude in tecplot with Flow-3d file? | his124 | FLOW-3D | 1 | June 27, 2011 10:54 |
tecplot 3D velocity contours inside a channel | vetnav | Tecplot | 4 | July 14, 2010 20:03 |
postprocessing Fluent Tecplot | unknown | FLUENT | 0 | October 11, 2009 06:34 |
