How to write read/write piecewise linear variation of properties in fluent
Like Tree3Likes
  • 2 Post By xrs333
  • 1 Post By vinerm
Old   February 3, 2012, 10:00
Default How to write read/write piecewise linear variation of properties in fluent
Yogesh Patil
foamcfd is on a distinguished road
I am running several cases which involves piecewise linear variation of 3 properties and functions. I wouldn't have problem if I have to enter for 4-5 pints. But I need to enter for around 15 points which is really painfull. So I was wondering if there is any way in fluent wherein I can read the file and it would update the linear variation of properties. So I don't need to do it manually.
Thanks
foamcfd is offline   Reply With Quote
Old   February 5, 2012, 11:02
xrs333
xrs333 is on a distinguished road
Use text command, here is a demo:
/define/materials/change-create aluminum steel ;;
yes constant 8030 ;; Density
yes piecewise-linear 8 300 505 900 585 1500 450 1600 690 1620 750 1621 3e4 1622 6e4 1623 9e4 ;; Cp
yes piecewise-linear 8 300 15 900 20 1500 30 1600 31 1620 32 1621 33 1622 34 1623 35 ;; Thermal_Conductivity
no ;; Overwrite?
Edit the command in a text-editor, copy these lines and paste them in the console of FLUENT, or run as a journal.
HHK and SSG_NJ like this.
xrs333 is offline   Reply With Quote
Old   February 7, 2012, 08:22
Yogesh Patil
Thanks. It works
Old   February 23, 2012, 22:13
Smile How to set a material(eg. aluminum or steel) to my gambit model in fluent?
subbu
subbu is on a distinguished road
I m from electrical background and i m new to this.. I hav created my wind turbine model in gambit and now i need two things to be done in it
1. to set aluminum as the material for one portion and remaining portion as steel.
2. want to simulate the model only for half rotation (180 degrees and not 360 degrees) in fluent
Anybody please help me out in this..
Thanks & Regards,
Subbu
subbu is offline   Reply With Quote
Old   March 31, 2020, 02:08
Default Journal file
Lee Jo
the_sixth_hokage is on a distinguished road
Originally Posted by foamcfd View Post
Thanks. It works
Hi...
I made a journal file to input conductivity and viscosity of fluid containing piecewise linear with 350 points...will this work...I read the files but when I tried to view it showed some warnings in console...how to confirm that my data is entered properly..
the_sixth_hokage is offline   Reply With Quote
Old   March 31, 2020, 03:52
Default Piecewise Linear
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Number of pieces is limited to 30 for piecewise linear properties. You have to use UDF for this.
the_sixth_hokage likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 2, 2020, 06:12
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Can you write also in ".scm" file format as in fluent database? I can write polynomial piecewise and had no problem however when I wrote piecewise linear material I got an error.
Thank you.
no ;; Overwrite?
atelcikti1 is offline   Reply With Quote
Old   April 6, 2020, 05:22
Default Material Property as Piecewise Linear
vinerm's Avatar
Vinerm
Scheme is just a language used by Fluent's cortex, i.e., its graphical interface. It does not mean that you can use it for something that Fluent does not allow. If the limit is 50 then it is 50. You cannot use scheme to include more than 50 pieces.
Regards,
Vinerm
How to write UDF programme inside FLUENT? coolyihao Fluent UDF and Scheme Programming 9 June 5, 2016 21:08
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
how to write a 3D linear temperature of UDF venus FLUENT 1 October 28, 2008 02:46
fluent -g does not write and print monitors Volker Pawlik FLUENT 7 December 7, 2005 06:19
Where can I write my C program "UDF" in Fluent Chimwemwe Banda FLUENT 2 December 8, 2004 09:07
