reading case and data file of fluent into the clusters
Old   February 6, 2012, 11:42
Default reading case and data file of fluent into the clusters
JOERIK
joerik is on a distinguished road
Send a message via Yahoo to joerik Send a message via Skype™ to joerik
I have been running the fluent simulation on a windows environment and wished to run same on the unix environment because of speed and time constraints. I usually get this error back when i open the output file.
connect to address **.**.**.*** port 544: Connection refused
after executing this command line
$ fluent 3ddp -t8 -cnf=/home/name/nodes -g -i script.txt > result.out
Please anyone with similar problem earlier?
joerik
joerik is offline   Reply With Quote
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 06:37
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam jlpelerin OpenFOAM Meshing & Mesh Conversion 4 April 25, 2011 16:56
Error in reading case and data file. Please Help! noa FLUENT 7 March 6, 2011 04:26
FLUENT can not read data file jing113cn FLUENT 0 December 6, 2010 09:06
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
