problem with unwanted faces..
Old   February 10, 2012, 18:00
Default problem with unwanted faces..
alejandro alonzo garcia
alejandro_1980 is on a distinguished road
Send a message via MSN to alejandro_1980
when i am trying to connect two meshed volumes that have a common face for conection...(example the cilinder out surface mesh is the same as the hole of a rectangular meshed volume (both face meshes are identical )gambit creates a unwanted wall...
how can i fix that problem with Tgrid???
or what can i do to dissapear that unwanted face???
alejandro_1980 is offline   Reply With Quote
Old   February 13, 2012, 01:21
-mAx-'s Avatar
Maxime Perelli
no idea with Tgrid (but should be the same as in gambit), but common faces, shold be set as interface, and then in Fluent create grid interfaces by selecting both interfaces
Old   February 13, 2012, 12:12
Default regards Max..
thank you for your asessment Max.. i m wondering. what about the link that you sent me last time?? the one about Tgrid in some chapter of Fluent .. i tried last time and does not work anymore..
thank you anyway...
Old   February 14, 2012, 07:17
-mAx-'s Avatar
Maxime Perelli
which one?
Old   February 14, 2012, 21:02
Default link
which one?
this link...http://cdlab2.fluid.tuwien.ac.at/LEH...ug/node138.htm .. but it is working again.. thank you Max..
problem : "reversed flow in 77 faces on outflow 12." aliamini FLUENT 15 February 6, 2014 14:06
problem due to reconstructPar? doubtsincfd OpenFOAM 0 June 3, 2011 16:16
[ICEM] Problem with meshing (uncovered faces, can't export bocos) hectordiaz ANSYS Meshing & Geometry 16 May 13, 2011 06:36
Converting Virtual Faces to Real Faces in Gambit gstraw Main CFD Forum 0 June 19, 2009 07:11
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
