Does anyone know how to simulate oil coating on the pipe wall in fluent?
Old   February 21, 2012, 11:33
Default Does anyone know how to simulate oil coating on the pipe wall in fluent?
Brian
yabin is on a distinguished road
Hi
I want to simulate oil&water flow in horizontal pipe. During the experiments, the obvious oil coating on the wall can be observed, which will affect the pressure gradient. In order to validate simulation results, I have to consider such oil coating effect in my model. Does anyone know how to implement this effect into CFD model?
regards
Brian
yabin is offline   Reply With Quote
Old   February 21, 2012, 12:24
athurlow is on a distinguished road
I'm a beginner to cfd but could you set the shear stress to a value under wall conditions?
athurlow is offline   Reply With Quote
Old   February 21, 2012, 14:25
Brian
Thanks, athurlow.
could you please specify more details or provide any hint about what shear stress I should define under wall condition?
Old   February 21, 2012, 14:39
Brian
currently, I assume the wall is no-slip. The flow regime simulated is oil core with water surroundings. but in some cases oil phase always tend to stick on the wall, namely, oil fouling.
Old   February 22, 2012, 07:26
I would put it as two boundary layers with different viscositys tau(shear)= mu du/dy so if u assume a simple linear profile for the oil and water and then let it develop. Not sure how right that is but that is how i would approach it
Old   February 22, 2012, 07:41
Brian
Yes, I agree with u. Actually, the water and oil are feeding into the pipe through T-shape and then developing. I also initialized three layer, which are oil film, water surrounding, and oil core. But when the oil core is stabilzed, oil film near the wall disappeared which means oil film cannot stick on the wall.
Old   February 22, 2012, 08:24
could you simulate no slip at the oil/wall interface - i doubt it would affect your results too much as long the shear transmitted at the oil/water interface is accurate.
Old   February 22, 2012, 08:35
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
Have a look to UDF user manual section :
8.2.3.1. Solidification via a Temperature-Dependent Viscosity
It may help you
Regards
laurentb is offline   Reply With Quote
oil coating
chtmultiregion: pipe in a wall NicolasB OpenFOAM Running, Solving & CFD 5 March 23, 2012 18:22
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Fluent pipe bends Sandy Main CFD Forum 0 July 10, 2005 17:26
