February 26, 2012, 08:20 |
Fluent default surface boundary condition
lalupp
Hi
Suppose we have a unnamed meshed surface in gambit and when this is imported in fluent 6.3, this would be assigned as wall (default) boundary zone Is there any way to set default boundary zone as interior in FLUENT I have a large mesh with lot of features naming each surface ,I found very difficult Any suggestion |
February 27, 2012, 02:41 |
I don't know if you can change the default settings, but otherwise you could wirte a journal-file which changes all boundary conditions to interior (if you knwo all the names).
February 27, 2012, 03:30 |
FLUENT will name wall (default) to those surfaces which have a mesh only on one side. FLUENT will name interior (default) to those surfaces that have mesh on both sides. In case you find an interior surface named as a wall then you need to fuse the 2 surfaces that are identical but belong to 2 different volumes.
Regards Luke |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Inlet boundary condition Fluent | natantyt | FLUENT | 0 | June 10, 2011 18:20 |
Slip boundary condition what is inside | normunds | OpenFOAM Running, Solving & CFD | 2 | June 4, 2007 06:45 |
