Converge problem for unsteady gas solid flow
Old   February 28, 2012, 13:27
Default Converge problem for unsteady gas solid flow
kong
kongl1986 is on a distinguished road
I am simulating gas solid flow for euler euler model in 10m circulating fluidized bed.
When I using a 18000cells mesh ,it converged well. and i can get the final solution about 12s flow time.
After refined it to 36000 and 54000 cells mesh, there is a converge problem.
the refined mesh only got converge before 4m or 2m from the inlet of bed, after that, the values monitored in rest of bed are keeping fluctuating when the flow time is more than 30s, although each time step shows that it converged.
The time step i am using is 0.0001s, the absolute criteria is 0.0001
can any one help me, thank you
kongl1986 is offline   Reply With Quote
Old   February 28, 2012, 20:54
Musango Lungu
Musa is on a distinguished road
Rule of thumb for setting time step is del t< delx/v
where del t= time step,del x = smallest mesh size, v= velocity. So make sure your time step is small enough for your refined mesh size. Next you can try and lower the under relaxation factor of pressure, momentum, volume fraction and K-epsilon if you are you using a turbulent viscous model.
Musa is offline   Reply With Quote
Old   February 29, 2012, 10:59
kong
for the 36000 cells mesh .the delx=0.00056m,and V=2.3m/s, so i think the time step is small enough, and i am using implicit scheme for volume fraction, and I check the manual of fluent, implicit scheme dont require the courant number
Old   February 29, 2012, 22:40
Musango Lungu
Okay, have you tried lowering the under relaxation factors?
Old   March 1, 2012, 16:28
kong
now i am using default underrelaxtion factors, cuz i found in each time step iteration, it got converge, if i change it, which one should i change?any clue to do this? thank you for your reply
Old   March 1, 2012, 16:31
kong
now ,i tried to use lower time step to see whether it works
converge, fluidized bed, gas solid
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem) jessie FLUENT 3 May 29, 2014 11:05
gas through porous media problem jiguozhao CFX 2 February 25, 2011 02:14
Gas Dynamic Problem afifi Main CFD Forum 0 May 5, 2009 06:41
Gas solid two phase flow Liwau CFX 4 March 19, 2004 11:08
