transient solution
Old   March 12, 2012, 10:03
Smile transient solution & generic transport equation
faw
Fara
faw is on a distinguished road
Hi everyone,
Just a general question, for transient model in fluent, if we use different time step sizes, why does the simulation results different? Is it because of the nature of the software (as we know that using smaller time step size will give more accurate results). What causes the difference in results? Is it because of the algorithm used (generic transport equation) in fluent as explained in this manual : https://www.sharcnet.ca/Software/Flu...th/node375.htm
based on the equation, does the change of dp��/dt (since dt changes when using different time step size) result in different results for different time steps?
Hope there's someone that can explain this in detail, thank you!
faw is offline   Reply With Quote
Old   March 12, 2012, 10:40
robboflea is on a distinguished road
One answer can be the fact that if I set a delta_t, so basically a sampling frequence, I set also the maximum frequence of non-stationary phenomena that can be possibliy captured by the solver.There are I guess also numerical aspects to be taken into account (my knowledge of which is really limited to be fair) but this can be surely an explanation (even if only partial) to your answer.
Cheers,
Rob
robboflea is offline   Reply With Quote
Old   March 12, 2012, 11:25
faw
Fara
Yes, you are right. That's what I've been thinking of actually..Sure, you did answer my question tho, and thanks Rob!
Does anyone else have any other opinions?
results, solution, time step, transient
Transient conduction possible in fluent? jlefevre76 FLUENT 2 February 5, 2013 09:53
Best practice for transient simulations? siw CFX 5 October 30, 2010 05:45
residual plot after solution reset plaunie STAR-CCM+ 1 April 3, 2010 06:53
Solution method for transient problems Roberto Ciardulli Siemens 10 November 28, 2000 04:38
steady and unsteady flow shisheng Main CFD Forum 10 July 23, 1999 06:00
