Why in invicid model it has vortex
Old   March 16, 2012, 03:45
Default Why in invicid model it has vortex
Yolk
Yannian is on a distinguished road
hi,
when I do a invicid model in which there are pressure jump(fan model), it generate vortex on the wall. Can you tell me the reason?Thank you!
Yannian is offline   Reply With Quote
Old   March 16, 2012, 04:18
Amir's Avatar
Amir
Amir is on a distinguished road
Your assumption is not right. Each inviscid flow is not necessarily irrotational!!! (e.g. rigid body rotation). Nevertheless, ensure that you've achieved converged solution.
Bests,
Amir
Amir is offline   Reply With Quote
Old   March 16, 2012, 04:35
Yolk
Originally Posted by Amir View Post
Bests,
Hi Amir,
The defenition of vorticity in my thread is the curl of velocity. If it is invicid,du/dy,du/dz,dv/dx ... are all zero, so the curl of velocity is naught. Please comment.
Old   March 16, 2012, 04:50
Amir's Avatar
Amir
Originally Posted by Yannian View Post
Hi Amir,
No!
The definition of inviscid flow is that the diffusion term of momentum equation can be neglected. As I said, in some cases like rigid body rotation this condition is satisfied but obviously the vorticity is not zero! i.e. :
Any irrotational flow is inviscid but not all the inviscid flows are irrotational.
I just wanted to clear this physical point for you but as a numerical point of view, when you use the inviscid model, you've ignored the elliptic term of momentum equation and it may cause some instabilities; consequently, you need more iterations for convergence. But as a tip, you can solve your case with full navier stokes equation and then use the converged results as your initial guess for inviscid flow. (This procedure is not common but can be used just for damping instabilities)
Bests,
Amir
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
How to model vortex of supersonic wing tip Bernard FLUENT 0 January 29, 2007 03:20
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 10:15
