March 24, 2012, 18:01 |
static mixer 2D
ahmed
Rep Power: 14 |
hi all,
i would like to get simulation of two miscible fluids into a (T) static mixer with( 2 inlet and 1 outlet) 6 obstacles using the EULERIAN Model with 2 same velocity, and volume fraction of the second fluid is: 1 my objectif is the homogenity point. the problem that i got the homogene point just after the 2 first obstacles( logicaly is wrong). could some one help me out |
August 3, 2012, 22:14 |
staic mixer
ahmed
Rep Power: 14 |
hi, can someone help me out???
August 4, 2012, 12:48 |
mohammad
Rep Power: 16 |
Dear ahmed
I am modeling a T micromixer now, and two fluids have the same properties correspondig to water at 300K. you need to turn on species. Your problem is not a multiphase flow. you can enter the volume fraction in Bc panel/ velocity inlet/ species. |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 00:49 |
Simulating a static mixer in Fluent | Novice | FLUENT | 1 | January 26, 2009 13:09 |
