Modeling the flow of solar radiation as the heat flux from the surface.
Old   March 25, 2012, 14:39
Default Modeling the flow of solar radiation as the heat flux from the surface.
Vasia Pupkin
Gebbels is on a distinguished road
Please help!
Need to model the heating of the solid bodies in the solar radiation. Want to set the flux of solar radiation as the heat flux from the surface. Tell me please, what should be the boundary condition on this surface.
I need a narrow beam of radiation, which is heated to the body inside the computational domain, while not heating the air. The air does not absorb heat and dissipate.
And I get the hot wall and the convective heat transfer with the air flow.
p.s. I can not apply the model of Solar Ray Tracing because the need is a narrow beam of light, which will get only a few of the items.
Gebbels is offline   Reply With Quote
Modeling Heat Flux using FLUENT ankurgahlot ANSYS 3 September 25, 2013 15:14
S2S Radiation Solar Modeling Help yus310 ANSYS 0 September 20, 2011 14:10
modeling pipe flow with strong surface tension phsieh2005 OpenFOAM 0 August 27, 2009 13:51
Channel Flow with Heat Flux svens OpenFOAM Pre-Processing 7 June 23, 2009 10:13
solar heat flux through roof Tim FLUENT 1 January 17, 2007 16:01
