Heat Transfert on fluent
Old   March 27, 2012, 09:09
Question Heat Transfert on fluent
Gauthier Carteni
Eole is on a distinguished road
Hi all!
I'm a student trying to modelise a heat exchanger on fluent. I use to work on Star-CCM+ so I don't really know fluent.
The simulation involve air (exhaust gas) and water vapor in a simple coaxial tube in conter-flow (3D simulation).
Exhaust gas:
Pressure: 1.5bar
Velocity: 61 m/s (mass flow 0.132 kg/s)
density: 0.4962 kg/m^3
Temperature inlet: 1047 K
Water Vapour:
Pressure: 4bar
Velocity: 28 m/s (mass flow 0.03 m/s)
density: 0.5542 kg/m^3
Temperature inlet: 416 K
Boundary conditions
Both velocity inlet customised with the number mentionned above
Both pressure outlet customised with number mentionned above
No slip conditions on walls
Thickness of walls where heat transfer happens: 5mm (in total)
Wall without heat transfer considered as adiabatic
My problem is ... both fluid temperature are decreasing and pressure in the exhaust pipe is not constant.
I'm not really a specialist in heat transfer and so in CFD simulation for heat transfer so maybe there is not enough detail here to let you help me. Let me know
Thank you!
Eole is offline   Reply With Quote
Old   March 28, 2012, 10:52
Snail
evswbok is on a distinguished road
i am facing the same problem
evswbok is offline   Reply With Quote
heat & mass transfer in fluent saha2122 FLUENT 1 July 31, 2011 14:39
Heat transfer in FLUENT no183 FLUENT 3 March 12, 2011 08:20
How to find the inbuilt equation in fluent for Heat Transfer Flux? rohitjvbibin Main CFD Forum 0 October 26, 2010 05:51
FLUENT heat transfer Chris FLUENT 4 November 24, 2002 01:17
May fluent can simulate heat and mass transfer? yueroo FLUENT 3 April 24, 2001 11:19
