please help issue with SuperMicro H12DSi-N6 and 7773X Milan-X |
April 7, 2022, 18:08 |
Abelardo Jara-Berrocal
Rep Power: 4 |
hi i hope everyone is well, i have got the 7773X part is it compatible with Supermicro motherboard? it works with the 7663 part Milan X with dual socket but wondering if it also works with the 7773X part
April 8, 2022, 02:25 |
Alex
Rep Power: 47 |
They are compatible, but you need a somewhat recent bios version.
https://www.supermicro.com/en/produc...oard/H12DSi-N6 Dual AMD EPYC™ 7003/7002 Series Processors (The latest AMD EPYC™ 7003 Series Processor with AMD 3D V-Cache™ Technology requires BIOS version 2.3 or newer) |
April 13, 2022, 10:19 |
worked but frequency are all to lowest
Rep Power: 4 |
Hi Flotus
many blessings putting the 7773x worked but now all frequencies are set to only 2.20 GHz max [07:16:09] abelardojara@abelardojara-Super-Server [~] $ cpupower frequency-info analyzing CPU 0: driver: acpi-cpufreq CPUs which run at the same hardware frequency: 0 CPUs which need to have their frequency coordinated by software: 0 maximum transition latency: Cannot determine or is not supported. hardware limits: 1.50 GHz - 3.53 GHz available frequency steps: 2.20 GHz, 1.90 GHz, 1.50 GHz available cpufreq governors: conservative ondemand userspace powersave performance schedutil current policy: frequency should be within 1.50 GHz and 3.53 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency: Unable to call hardware current CPU frequency: 1.49 GHz (asserted by call to kernel) boost state support: Supported: yes Active: no is there a solution please how get the frequency to max 3.53 please? |
April 13, 2022, 11:10 |
Alex
Rep Power: 47 |
Don't trust the output of cpupower.
Use turbostat instead, it gives you the actual frequency each core is currently running at. Of course, you need to apply a single-core load in order to see the maximum turbo frequency. If this still yields results that are too low, you can investigate further. |
April 13, 2022, 12:34 |
you are the best thank you but still shows low frequencies
Rep Power: 4 |
first and foremost thank you, thank you and thank you
1 1 51 243 9 0.55 1565 2196 0.22 10 0 0 7 0.00 0.00 99.81 1 1 52 116 8 0.52 1561 2196 0.23 11 0 0 7 0.00 0.00 99.79 0.00 1 1 52 244 8 0.51 1530 2196 0.25 10 0 0 7 0.00 0.00 99.77 1 1 53 117 8 0.56 1492 2196 0.29 10 0 0 7 0.00 0.00 99.69 0.00 1 1 53 245 8 0.49 1553 2196 0.31 10 0 0 7 0.00 0.00 99.75 1 1 54 118 8 0.50 1642 2196 0.25 10 0 0 7 0.00 0.00 99.78 0.00 1 1 54 246 7 0.46 1612 2196 0.26 10 0 0 7 0.00 0.00 99.82 1 1 55 119 10 0.63 1518 2196 0.20 10 0 0 7 0.00 0.00 99.76 0.00 1 1 55 247 10 0.65 1489 2196 0.25 10 0 0 8 0.00 0.00 99.75 1 1 56 120 6 0.39 1517 2196 0.33 10 0 0 6 0.00 0.00 99.73 0.01 1 1 56 248 5 0.31 1567 2196 0.38 10 0 0 6 0.00 0.00 99.81 1 1 57 121 6 0.37 1552 2196 0.34 9 0 0 6 0.00 0.00 99.78 0.00 1 1 57 249 5 0.33 1552 2196 0.37 9 0 0 6 0.00 0.00 99.82 1 1 58 122 6 0.38 1675 2196 0.31 11 0 0 6 0.00 0.00 99.79 0.01 1 1 58 250 6 0.34 1691 2196 0.33 9 0 0 6 0.00 0.00 99.82 1 1 59 123 7 0.45 1612 2196 0.26 8 0 0 6 0.00 0.00 99.80 0.01 1 1 59 251 7 0.41 1620 2196 0.28 8 0 0 6 0.00 0.00 99.84 1 1 60 124 7 0.45 1639 2196 0.29 14 0 0 10 0.00 0.00 99.74 0.01 1 1 60 252 7 0.41 1641 2196 0.32 16 0 0 10 0.00 0.00 99.78 1 1 61 125 6 0.40 1591 2196 0.31 8 0 0 6 0.00 0.00 99.79 0.01 1 1 61 253 6 0.36 1583 2196 0.33 8 0 0 6 0.00 0.00 99.83 1 1 62 126 7 0.46 1562 2196 0.28 10 0 0 7 0.00 0.00 99.77 0.00 1 1 62 254 6 0.41 1578 2196 0.30 11 0 0 7 0.00 0.00 99.82 1 1 63 127 3 0.20 1733 2196 0.55 9 0 0 7 0.00 0.00 99.84 0.28 1 1 63 255 261 12.22 2135 2196 2.42 21 0 0 7 0.00 0.00 87.83 this was the output of the tail of turbostat, still no core passes the 2.2 GHz |
April 13, 2022, 14:26 |
Alex
Rep Power: 47 |
And what exactly did you use to simulate a load?
From the output you posted, my best guess is that you stressed pretty much all cores. You can't expect to see the highest single-core boost frequency under an all-core load. |
April 13, 2022, 17:52 |
bssl
Rep Power: 4 |
Hi flotus I hope you are well
I run boringssl speed and gets high cpu on most cores, however still frequency is capped at 2.2 ghz cpupower freq-info shows 3.5 ghz as maximum hardware can do but however available frequencies only show 1.5, 1.9 and 2.2 so a lot of frequencies are missing do you know what i could do? i dont see anything in bios to change acpi for processor |
April 13, 2022, 18:27 |
Alex
Rep Power: 47 |
Just so we are on the same page here, this is what cpupower frequency-info shows on my machine:
cpupower frequency-info analyzing CPU 0: driver: acpi-cpufreq CPUs which run at the same hardware frequency: 0 CPUs which need to have their frequency coordinated by software: 0 maximum transition latency: Cannot determine or is not supported. hardware limits: 1.20 GHz - 2.00 GHz available frequency steps: 2.00 GHz, 1.60 GHz, 1.20 GHz available cpufreq governors: ondemand performance schedutil current policy: frequency should be within 1.20 GHz and 2.00 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency: Unable to call hardware current CPU frequency: 1.20 GHz (asserted by call to kernel) boost state support: Supported: yes Active: no If you absolutely can not get a single core (read: all other cores idle) to run above base frequency, then the first guess is that turbo boost is disabled in bios. The setting is called "core performance boost" in the "CPU configuration" menu and needs to be set to auto. I assume you already have the latest bios version installed? |
