Home > Forums > General Forums > Hardware
Linux cluster for Fluent 6.3.26
Old   April 3, 2009, 23:44
Exclamation Linux cluster for Fluent 6.3.26
Far
Sijal
Hello
I want to install the fluent 6.3.26 64 bit version on dell power edge 2950 system (intel cpu). I have 4 systems. Each system having 8 cores and 16 GB RAM. Master node has additional 16 GB RAM (16+16= 32GB RAM). My operating system is Ret Hat EL 5.0
When i try to run fluent following error is occured: Error:directory /CFD/Fluent.Inc/fluent[0-9]* does not contain a valid arch. Set the environment variable FLUENT_ARCH and try again
In response to that I have set the Fluent_Arch and exported it but the problems remains there. Any suggestion will be highly appreciated.
Best Regards
Old   April 5, 2009, 05:16
Default To Jonas:
Far
Sijal
Dear Jonas; plz help in this regard nd if possible please post the procedure of setting up the fluent on linux on wiki. Best Regards
Old   April 5, 2009, 07:36
Administrator
jola's Avatar
Jonas Larsson
jola is on a distinguished road
Send a message via MSN to jola Send a message via Skype™ to jola
It was more than 10 years ago since I installed Fluent so you'd better ask someone else for help. Fluent support should be able to help you.
jola is offline   Reply With Quote
Linux Cluster Manager from SGI out for X86 Shelly Zavoral Main CFD Forum 0 February 13, 2009 12:26
LINUX cluster and server azmir Siemens 6 September 17, 2006 19:09
Linux Cluster Performance with a bi-processor PC M. FLUENT 1 April 22, 2005 09:25
Linux Cluster Setup Problems Bob CFX 1 October 3, 2002 18:08
To Jonas: Linux Cluster Mark Render Main CFD Forum 1 June 20, 2002 04:19
