Rocks 5.4 Rsh Connection Refused for Fluent 6.3 |
August 1, 2011, 10:03 |
bucnik
Dear All,
I am new to CFD and for linux. I have a 8 node machine. I was advised that I should install a cluster software for performing fluent 6.3 version in parallel. I have installed rocks 5.4 on the frontend and subsequently installed on all the 8 nodes. I have checked the interconnectivity with ganglia and all the nodes are up. I have then installed on fluent 6.3.26 on the frontend. when I run fluent in parallel i get rsh connection refused error. I have researched a bit on that on internet and found that by default rsh is disabled in rocks and need to be enabled. I have setup a .rhosts file, hosts.equiv file, changed the settings in pam.d directory, installed rsh server, disabled firewall. Still the fluent does not work. I have even tried rsh on the bash prompt. still the same error. initially the error says that krb5 is refused, the krb4 is refused then normal rlogin is refused. I have tried ssh it works fine with password. i linked rsh and ssh by ln command. still i get connection refused. When I try rsh from the nodes to the frontend somehow it works. again between nodes rsh doesnot work. please suggest what I am supposed to do. Any other cluster software which is a bit user friendly. I am more interested in running fluent than working on the operating system. |
March 29, 2012, 04:00 |
supporter
Dear
I am facing same problem as u, but i change the script to use ssh instead of rsh, i.e. add -ssh in your fluent command script to run job using ssh. in this way my job runs smoothly & got the results. |
March 29, 2012, 16:24 |
#3 | |
Charles
Rep Power: 18 |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
mpid: No such file or directory [urgent] | myfluentid | FLUENT | 10 | October 22, 2013 17:00 |
Installation on Rocks 5.4 | tonyuprm | OpenFOAM Installation | 4 | January 25, 2011 12:59 |
connection refused problem | RX | Siemens | 3 | November 24, 2006 16:57 |
Parallel Process: RSH Connection | xc | FLUENT | 5 | August 11, 2005 15:44 |
