Does anyone know what BC's to set in ICEM 5.1 to successfully read into Fluent6? I can write the mesh file and select the appropriate wall/inlet/outlet conditions.. But I believe my problem comes with setting the interior and fluid domains (which GAMBIT previously did for me). Or is there another trick involved with stting the mesh as structured/unstructured?
ICEM tutorials on this seem to be non-existent |
You don't need to set any BCs in ICEM CFD. For Fluent6 you'll need unstructured format mesh - so tets/prisms or unstructured hexas. You'll probably want to write the Fluent mesh as ASCII as well. The families/parts from ICEM CFD should come through as regions/zones in Fluent - both surfaces and volume regions. If you haven't retrieved the Service Packs (1 and 2) for ICEM 5.1 - you'll want to do that as well. If you continue to have problems, contact your technical support provider.
Export 2D mesh from ICEM to Fluent | enghamed | ANSYS Meshing & Geometry | 18 | August 10, 2015 20:49 |
[ICEM] domain interface in ICEM for fluent | hsn | ANSYS Meshing & Geometry | 24 | November 27, 2012 16:43 |
Dimension conflict between icem cfd and fluent | highhopes | ANSYS Meshing & Geometry | 1 | September 9, 2011 11:07 |
Problem with ICEM and Fluent: Automatically created Regions within the domain | sandmike_83 | ANSYS Meshing & Geometry | 0 | September 24, 2010 05:42 |
ICEM 2d mesh to fluent | hsn | CFX | 2 | June 5, 2008 14:45 |
