CFD of tilting disk check valve
Old   July 13, 1999, 16:23
Default CFD of tilting disk check valve
Greg Anderson
Does anyone know of any CFD consulting firms that can model a tilting disk check valve with the following parameters?
24" Crane 5° tilting disk check valve
Flowrates will range from 100 gpm to 12000 gpm
I have talked with Fluent and they said that they had a Beta test version of their code that would combine the fluids and structures components, but are not sure of the accuracy yet..
Note: Structures are required since part of the problem is to determine the disk position and if the disk flutters at the low flows.
Old   July 13, 1999, 17:07
Default Re: CFD of tilting disk check valve
Raza Mirza
CFD Research Corporation (CFDRC) provides software and consulting services for CFD. We have a fully functional code (CFD-ACE+) to do coupled fluid-structure interaction problems. It is also being currently used by our clients for such applications.
Please visit our home on the web http://www.cfdrc.com. Please contact Mr. Fritz Owen (sfo@cfdrc.com; 256 726-4827) to get more information on consulting services we provide.
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 06:41
CFD Symposium (Call for Papers) Chris R. Kleijn Main CFD Forum 0 October 5, 1998 10:25
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 08:19
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 08:45
salary range Frank Muldoon Main CFD Forum 7 August 3, 1998 19:04
