May 17, 2012, 19:18 |
comparison with DNS
hars
I have been trying to perform CFD analysis of isotropic turbulence using LES like scheme. In order to compare my results with DNS,should I be finding the parameters like intergral length scale(to find turn over time) from my scheme or take the DNS value. Thanks a lot......
May 18, 2012, 04:17 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
May 18, 2012, 17:44 |
hars
Hi, thanks a lot for the reply.... when i want to plot the total energy for example, the time axis is generally non-dimensionalized which involves a length scale(integral length scale). should i obtain this value from a DNS or calculate from my code?... thnx a lot
May 19, 2012, 04:16 |
Rep Power: 71 |
in homogeneous isotropic flows the characteristic lenght scale is generally the Taylor micro-scale lambda, on whcih the Reynolds number of the computation is based too. Use information from DNS as in LES you have a cut-off of the smallest scales (only scales in the inertial range are computed) and you cannot compute the Taylor length.
May 21, 2012, 18:37 |
hars
thanks a lot for clarifying......
Everything you need to compute DNS in channel vs OF 2.1.0 | levka | OpenFOAM Running, Solving & CFD | 41 | October 30, 2023 11:17 |
DNS in Turbulent S.O.S. Urgent | Hengky | FLUENT | 11 | September 28, 2006 10:07 |
what is DNS ? | Phillip | Main CFD Forum | 10 | August 28, 2003 15:28 |
Complicated Homogeneous Shear DNS | ff_fan | Main CFD Forum | 0 | December 9, 2002 18:23 |
DNS of homogeneous shear flow: comments please! | ff_fan | Main CFD Forum | 1 | September 12, 2002 02:28 |
