Potential Flow Solver
Old   May 23, 2012, 19:28
Talking Potential Flow Solver
Gordon L. Nelson
GLNAIR44 is on a distinguished road
Is it correct to say there are basically three types of flow solvers? As I understand it these can be classified as potential flow solvers, density based solvers and pressure based solvers. Turbulence models are just turbulence models - - they fall outside any of these categories.
GLNAIR44 is offline   Reply With Quote
Old   May 24, 2012, 01:44
Martin Hegedus
Martin Hegedus is on a distinguished road
I would say the three main categories of solvers based on assumptions of the physics are potential, Euler, and Navier Stokes. Of course there are all sorts of sub categories, for example steady, unsteady, compressible (subsonic, transonic, supersonic, hypersonic), incompressible, laminar, RANS, URANS, LES, DNS, etc.
On the other hand, density based solvers and pressure based solvers says something about how a solution is obtained (along with giving an idea of the type of flow being solved for).
Martin Hegedus is offline   Reply With Quote
Old   May 24, 2012, 17:46
Gordon L. Nelson
Thanks for the reply. From what little I know about turbulence models, it seems that the so-called Navier-Stokes solvers do not solve the N-S equations. They solve some fobbed-up set of algebraic or differential equations that represent a mean flow of some kind. They also have a lot of empiricism built into them, and none of them are very general. It's always seemed to me that these solvers are more like the empirical equations of hydraulics than they are any kind of fundamental solver. I think the latter class (i.e.-'fundamental' solvers) is at the present moment essentially an empty set, at least for turbulent flows.
Here is my real question: Seems that if one wants to solve for, say, the flow over an airfoil at a high angle of attack, a nonlinear potential flow solver coupled with some kind of a turbulent wake model would be preferable to either a density-based or a pressure-based model, simply because (at least in the outer region) you are solving a single PDE instead of three or four. Is this too naive?
Old   May 24, 2012, 18:22
cfdnewbie
cfdnewbie is on a distinguished road
Then the people calling it a navier stokes solver are imprecise. What you are referring to is probably RANS, and yes, thats the full navier stokes equations plus some algebraic or differential modeling terms.
If you mean by fundamental a solver that solves just the navier stokes equations, they are everywhere - i would wager that all meaningful commercial solvers do that, and almost each grad student in cfd probably has written his own ... They are all as general as the navier stokes equations themselves.
I would guess that about 20% of the world's supercomputers do nothing but solving the ns equations at a given time
I admit that i am not familiar with the capabilitirs of nonlinear potential theory. What i remember from linear potential is that it cannot produce vorticity nor a boundary layer. A flow over an airfoil at high aoa is highly rotational, plus the bl will play a role as well.... So i guess that would rule out potential theory completely.
I am not aware of people computing turbulence in wakes, jets or around bodies ever doing anything else but Navier Stokes, but i have to admit i m not familiar with the nonlinear potential flow. A quick google search gave me very few pappers on this from the 80s, i guess its not considered anymore.
cfdnewbie is offline   Reply With Quote
Old   May 24, 2012, 18:38
Gordon L. Nelson
Thanks for this. It is quite illuminating.
Old   May 24, 2012, 18:52
Martin Hegedus
The Navier Stokes solvers do solve the N-S equations. It's the Reynolds Averaged Navier Stokes (RANS) solvers which solve (or try to solve) for the mean flow by inserting eddy viscosity.
Potential codes have been hooked up to boundary layer codes to calculate the lift and drag on an airfoil. But, in general, that is for flow without separation (and therefore not high angle of attack) and it is not for 3D viscous flow. That's not to say some haven't pushed this class of code somewhat into these regions.
In general, the performance of potential codes should be compared to the performance of 2D incompressible/subsonic (uncoupled pressure based) solvers. Sure they are faster, but, for a 2D geometry, I'm not sure many would really care due to the high performance of computers. Maybe if someone is doing optimization or a trajectory, but even then I doubt it would really matter much anymore.
In general, a coupled Euler density solver (as apposed to uncoupled pressure based) is meant for transonic and above (i.e. greater than supercritical). In this region the accuracy of potential solvers degrades due to the assumptions for potential flow. Therefore, in general, full potential flow and coupled Euler density solvers target two different flow regions.
Of course one could use an Euler density solver to solve for low subsonic speeds (the realm of potential and Euler uncoupled pressure based solvers), but the convergence rate will suffer and at some point one will need to go to Mach number preconditioning.
Also, in general, flux splitting schemes (which have not been adapted to potential as far as I know) capture and track vorticity better.
Old   May 24, 2012, 19:30
Martin Hegedus
Oh, just want to be clear.
Full potential was used in the past, and is still used, for optimizing wings at transonic speeds. However, as far as I understand, it is challenging for them, due to the lack of a good boundary layer model and the assumption of isentropic flow, to capture the position of the shock. Therefore, the wave drag is off.
density based, potential flow, pressure based
Suitable solver for Air/Air flow with different temperatures cjm OpenFOAM 1 January 20, 2011 04:17
Troubleshooting Unsteady Incompressible Flow Solver dandalf Main CFD Forum 0 November 15, 2010 10:55
What solver to use for inviscid flow simulation over missile mecbe2002 OpenFOAM 0 April 27, 2010 11:10
2D Unsteady Potential Flow Solver A.S. Main CFD Forum 2 November 16, 2005 03:38
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
