2D Field Panel Method Source Code
Old   November 8, 2005, 01:24
Default 2D Field Panel Method Source Code
Shukla
Anybody having 2D field panel method source code. Any pointer to available source code will also be helpfull.
Thanks
Shukla
Old   November 8, 2005, 06:12
Default Re: 2D Field Panel Method Source Code
James Date
Katz J., and Plotkin A., "Low-Speed Aerodynamics: From Wing Theory to Panel Methods," McGraw-Hill Book Co., New York, NY, 1991.
Old   November 8, 2005, 06:56
Shukla
Thanks James
Old   January 20, 2011, 12:51
Unhappy 2D unsteady panel method kutta condition
Amit Singh
amitsingh178 is on a distinguished road
I'm working on a 2D unsteady panel method for harmonic oscillations of a NACA 0012 airfoil. I've been trying to debug the code for ages. I'm getting a nice sinosoidal variation for the lift force but the value of amplitudes are not satisfactory. Does anyone have any source to verify the values I'm getting. Also, while implementing the kutta condition(Basu and Hancock), I'm getting a quadratic equation. So, to choose the correct root, the one closest to the last time step values is chosen. But at even slightly higher frequencies, the two roots are very close and the code doesn't converge anymore. So, I want to know whether there is a better way to choose the correct root so that I can reach higher frequencies.
Thank You.
amitsingh178 is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Open Source Code for Lattice Boltzmann Method Halim Main CFD Forum 34 November 14, 2019 01:27
PANAIR: PANEL METHOD CODE Yogesh P Main CFD Forum 9 October 26, 2015 18:04
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Open source panel code Jean Main CFD Forum 2 February 29, 2008 22:19
