prob at high inlet velocities
Old   November 27, 2005, 21:54
Default prob at high inlet velocities
nkc
Hi:
I am working on a 3D NS solver using SIMPLE method. Could anyone please advise on the following:-
(1) For a typical backward-facing step problem, the solution converges well at relatively low inlet velocities. However, at high inlet velocity (say 5-10 m/s; Re = 3000), the code just cant take it and diverges.. can anyone please explain why this happens? Anyone experienced this before?
(2) Regarding the coefficients (ap) built for the momentum equations, some authors claimed that they are indeed the same for the 3 momentum equations.. Is that absolutely true, particularly at the cell near to the wall, when the shear forces are applied only to the velocity components parallel to the wall?
Thank you.
Problems with Inlet species San24 Siemens 1 May 7, 2008 06:29
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 10:22
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
pressure boundaries allowing inlet velocities cirilo Siemens 1 September 7, 2005 03:21
why the static pressure in inlet of fans was high jimmy Fidelity CFD 2 October 10, 2003 07:25
