December 14, 2005, 08:48 |
Boundary Conditions
I want to simulate the flow of water in a tank. Suppose the one side of the tank is open at upstream end and the water is coming in from this side. The same quantity of water is going out from the correspoding downstream end keeping the water level constant. Of course, the bottom boundary will be non slip wall boundary conditions (BC) where all the velocity componants are zero. Near side wall and far side wall BCs will also be same as the bottom. The BCs on top of the water surface will be slip wall type. What about the boundary condition on upstream side wall and downstream side wall? Thank you in adavance... Sas..
December 14, 2005, 20:22 |
Re: Boundary Conditions
If I am understanding you correctly, the flow is for a tank with four wall and two inlets. The four walls all should be modelled with no-slip (zero velocity) conditions.
December 14, 2005, 23:43 |
not fully understood. however, inlet conditions if and when known - Dirichlet type. outlet condtion when not known - Neumann type 1st deriv (or second deriv even better from physics point).read patankar.
December 16, 2005, 13:47 |
The following answer is assuming that you are considering an incompressible assumtion ---
In the upstream side a Dirichlet condition has to be specified. In you case it would be velocity of water entering the tank.(u=U_inf, v=0,w=0) and no condition on pressure On the Downstream side a Neumann condition has to be specified. An efficient condition is to set the variation of normal stress to zero. |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 05:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
