which open source meshing software exports in cgns?
Old   July 23, 2012, 14:02
Default which open source meshing software exports in cgns?
Viggy Palaniappan
spitfire is on a distinguished road
I'm using a newly released solver SU2 and would like to do a mesh convergence study.
The problem I have is that the program requires meshes to be in the .cgns format and atm I'm really struggling to find any open source mesh generators that allow you to export in this format. Commercial mesh generators (like Pointwise/Gridgen) are capable of doing so but I don't have access to them.
Are there any open source mesh generators that allow you to export in this format? Or can i create the mesh in another format and then use a converter? I'd love some help please. =)
spitfire is offline   Reply With Quote
Old   July 23, 2012, 19:15
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
You could use openFoam as an intermediate format and then use foamToCgns (which I think is part of the standard distribution). I have no personal experience and it probably is not straightforward.
BTW: I had a look at SU2 and when I noticed that they had their own mesh format or CGNS, I left it in the too hard basket...
Cheers.
Julien
julien.decharentenay is offline   Reply With Quote
Old   July 24, 2012, 03:50
Oliver Gloth
ogloth is on a distinguished road
the native SU2 format is incredibly simple. We have an export function in our open-source mesher enGrid (see http://engits.eu/en/engrid). I have tried to use SU2 myself, but I had problems when using highly an-isotropic boundary layers. It turned out that this might be due to a too low accuracy for the output file. If you try it and you run into problems, please drop me a note.
Cheers,
Oliver
ogloth is offline   Reply With Quote
Old   August 8, 2012, 16:14
Viggy Palaniappan
I get the following error message when trying to export with CGNS:
CGNS support has not been compiled
file:cgnswriter.cpp
line:333
How do I get it working? Thanks
Old   August 20, 2012, 10:16
AeroMike is on a distinguished road
If you are just using structured grids it is very easy to generate them using a really simple Fortran code. There are some really good examples which are easy to follow provided by the NASA website: http://www.grc.nasa.gov/WWW/cgns/CGN...r/started.html
Mike
AeroMike is offline   Reply With Quote
Old   August 20, 2012, 12:18
Viggy Palaniappan
No, unfortunately, I need an unstructured grid
Old   August 20, 2012, 12:19
Ah, in that case it is do-able but potentially a lot tricker, I don't have any experience with writing grid gens for unstructured cases, sorry!
Old   August 20, 2012, 12:22
Viggy Palaniappan
Do you know how to get cgns support on for meshers like Gmsh? That seems like the best open souce mesher to me but I still can't get CGNS to work.
Old   August 20, 2012, 12:25
Sorry, no experience with anything other than commercial and writing my own generators.
Old   August 21, 2012, 00:11
Praveen. C
praveen is on a distinguished road
If you want to use gmsh, you can easily rewrite the file in SU2 native format. I have some code here
https://code.google.com/p/cfdlab/sou...trunk/3d/grid/
There is a gmsh2cgns program which can handle tetrahedral grids only but you should be able to modify it for general case. The generated cgns grids work with freecfd but I have not tested with su2.
If you use them and have some success/failure please let me know.
I would recommend directly converting gmsh format to su2 format, rather than using cgns format.
praveen is offline   Reply With Quote
Old   August 21, 2012, 05:35
Default @spitfire
  #11
Oliver Gloth
Sorry, I missed your post with the CGNS problem.
If you are using enGrid, you can directly export to SU2 format -- no need for CGNS. You might have to check out the branch called "release-1.4" from our GIT repository (the default is still 1.3). In order to do that you can edit the script "build.bash", or if you know your way around GIT it is very easy.
If you get stuck, please look at the enGrid Wiki, or use the enGrid forum (I check that on a regular basis).
Btw. I am also interested in any feedback you have with SU2 ;-)
Cheers,
Oliver
Old   September 2, 2012, 15:30
Viggy Palaniappan
Thanks all, I ended up writing my own mesh conversion tool in matlab to go from the .geo (Gmsh) to .su2 (SU2).
interFoam & decomposition method: scotch MacGyver OpenFOAM Running, Solving & CFD 2 May 23, 2012 07:00
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
Could the CFD community benefit from Open Source? JF Main CFD Forum 13 December 17, 2006 23:06
Open source software and commercial CFD YF K Main CFD Forum 2 January 7, 2003 01:11
