December 22, 2005, 08:46 |
Initial cinditions for incompressible fluid
Hello! I'm developping a simple code for incompressible fluid. I have one problem. How could I get initial condition that satisfies continuity equation, boundary conditions and compatibility condition? I have not found anything about that anywhere. Or can I use Ui = 0 everywhere when I have nonzero Dirichlet condition on U1 at inlet?
December 22, 2005, 13:05 |
Re: Initial cinditions for incompressible fluid
Why don't you use the free stream condition as the initial condition i.e ui=U_inf, vi=0,wi=0 U_inf is the velocity at the inlet also.
December 23, 2005, 09:15 |
Thanks! I was not sure if they are correct if have noslip BC in domain also. I am beginner and in my books (Wesseling, Ferziger - Peric ...) was not much about that.
December 23, 2005, 10:45 |
Vladimir,
Solution convergence can often be a little easier if you 'pre-fill' the fluid domain with a prescribed initial velocity. It also leaves less work for the solver to perform. diaw... |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
