August 1, 2012, 02:02 |
Compressible Navier-Stokes
Is it possible to solve compressible NS equations with non homogeneous divergence (grad . V = f, f is some function not equal to zero) using FDM?
August 1, 2012, 05:00 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Your question is not very clear to me... you are simply stating that you want to solve the compressible form wherein the density equation writes as Div V = f = -(1/rho) (d rho/dt + V . Grad rho) why are you asking about FDM? The equations can be solved by FDM, FVM, FEM .... |
August 1, 2012, 20:22 |
My problem is flow of a fluid mixture. Water + particles. There is a source of particles and hence the density changes and continuity has a source term. Fluid is not compressible but the density changes with time. I used f for the function for particle source. Thanks.
August 2, 2012, 06:28 |
#4 | |
This is a hard task but to tackle this problem you should use the local averaged Navier-Stokes equations which introduce the void fraction. The continuity equation which is derived is d(eps)/dt+ div(eps.U)=0 (d/dt is here the time partial derivative, div the divergence operator and eps is the void fraction). You should also compute the interactions between particles (collisions + lagrangian Newton's law solver) and from their positions the void fraction at each time step and for each cell. There is also a source term in the averaged NS equations which is the resultant of the drag force on the particles. This force accounts for the interactions acting on the fluid due to the presence of particles. You may found a lot of references in the litterature. |
August 3, 2012, 01:26 |
Thanks all
easy educational compressible navier stokes implementation anywhere? | Boogiwoogie | Main CFD Forum | 0 | December 19, 2010 06:32 |
Compressible navier stokes | fatih | Main CFD Forum | 1 | October 1, 2007 17:31 |
2d compressible Navier stokes | selim | Main CFD Forum | 0 | July 6, 2007 11:24 |
Newbie:Viscoelasticity and Navier stokes equation | Rajil Saraswat | Main CFD Forum | 2 | June 9, 2003 07:21 |
help: I am trying to solve Navier Stokes compressible and viscid flow | Jose Choy | Main CFD Forum | 2 | May 18, 2000 05:45 |
