Boundary Condition
Like Tree1Likes
  • 1 Post By Maged_CFD
Old   September 19, 2012, 02:32
Default Boundary Condition
Prashant Kumar Singh
pks126 is on a distinguished road
Hello
I have given BC at inlet of a compressor as velocity profile and total T
And at outlet BC as mass flow rate but it did not run, showing error that P is not mention at any boundary.I wanted to know is it necessary to give Pressure as a BC in case of compressor at any one of the boundary.
If my compressor outlet is going into the atmosphere then what could be the pressure(total/static) boundary condition at outlet plane.
Thanks
Prashant
pks126 is offline   Reply With Quote
Old   September 22, 2012, 20:01
Default Re: Boundary Condition
Maged
Maged_CFD is on a distinguished road
Hello Prashant,
You need to set the boundary condition at the outlet as:
P_static = atmospheric pressure
Note that your outlet plane should be far enough from the compressor blades.
khalid khedir likes this.
Maged_CFD is offline   Reply With Quote
Old   September 24, 2012, 01:18
Thanks Maged_CFD
I did same thing and give outlet static P 101325Pa and after completion in cfx also shows outlet static P as 101334Pa which ony 9pa higher i think this BC is ok.
thanks once again
Old   October 31, 2012, 05:15
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
You need to set both inlet and outlet boundary conditions as pressure. You calculate the inlet velocity from the compressor flow coefficient (phi) and dynamic pressure (Pv) as well. Then you calculate the inlet static pressure (Ps=Pt-Pv). Pt as total pressure and Ps as static pressure. the outlet static pressure can be calculated by the compressor head coefficeint (si). By in entering these BCs your solver will be able to calculate the velocity and pressure field.
Best regards.
vicarious is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
