Combusting flow with incompressible code?
Old   September 20, 2012, 05:06
Default Combusting flow with incompressible code?
michujo is on a distinguished road
Hi everyone, I have a question concerning the computation of a reacting flow (combustion).
Do you think it is possible to compute a flame using the SIMPLE method?
What I think is that, assuming steady state (so no acoustics going on) and for low-Mach number flows, the gases are essentially incompressible (density differences only due to temperature changes, since the pressure is almost constant accross the flame), therefore I think that it is possible to compute it with an incompressible code (I'm particularly referring to the methodology proposed in Versteeg & Malalasekera or Patankar).
Thanks in advance.
Cheers,
Michujo.
Last edited by michujo; September 20, 2012 at 05:08. Reason: ortography correction
michujo is offline   Reply With Quote
Old   September 20, 2012, 11:06
Yon Han Chong
yonchong is on a distinguished road
Yes. Most of the combustion CFDs are done using SIMPLE and incompressible.
yonchong is offline   Reply With Quote
Old   September 20, 2012, 17:14
leflix is on a distinguished road
the use of SIMPLE is not a characteristic of incompressible flows. You can use SIMPLE algorithm even for compressible flows.
The question is more can we use a incompressible solver for combustion problem? If your mach number is below 0.3 I guess we can...
leflix is offline   Reply With Quote
Old   September 20, 2012, 17:20
Hi guys, thanks for your feedback.
You're right, I was referring to the use of an incompressible code for combustion, so you pretty much gave a satisfactory answer . I still have some questions though. For instance: let's say that density depends on temperature, and I compute it as rho=function(T), would mass still be conserved?
My experience with combustion is using a non-commercial LES compressible solver so I was not familiar with the use of compressible codes for combustion. Do you guys know of any good reference that i could check in this regard?
Thanks again.
Cheers,
Michujo.
Old   September 20, 2012, 17:28
Yon Han Chong
I would recommend using ideal gas option for calculating density. Most of (if not all of) them should have it.
Old   September 20, 2012, 18:01
Thanks yonchong. Actually I ask so because I have in mind developing a 2D incompressible code of my own, so no commercial. Given that pressure is constant (except for the few kilopascals that would drive the flow), the ideal gas law is reduced to a function solely of temperature, is it not? (although I'll have to deal with the change of molecular weight of the gas for a multispecies flow...). Too many doubts!
Thanks.
Cheers,
Michujo.
Old   September 20, 2012, 18:21
Yon Han Chong
Pressure may not be changing but still need to calculate density.
Old   September 20, 2012, 18:25
Yon Han Chong
By the way, if you are trying to write your own CFD code have a look at these posts.
http://www.cfd-online.com/Forums/mai...-language.html
http://www.cfd-online.com/Forums/mai...tml#post376764
Old   September 20, 2012, 19:21
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Michujo,
Mass conservation in SIMPLE (or any pressure based algorithm) is achieved in the pressure correction step. As long as the pressure correction step includes the density variation associated with variation in temperature, the mass is "conserved" - I used inverted comma here as mass conservation depends on how good the pressure solver is and the tolerance used. As a good practice I would recommend that you implement a mass conservation check.
I would recommend doing a bit of reading on the derivation of the low Mach number approximation for pressure based equation (google dilatable incompressible low Mach number equation may give you to the right answer). Otherwise I can try to dig out the references from my PhD (unsteady simulation of reactive flow at low Mach numbers).
Julien
Last edited by julien.decharentenay; September 20, 2012 at 19:23. Reason: Added comment on pressure solver for mass conservation.
julien.decharentenay is offline   Reply With Quote
Old   September 21, 2012, 02:41
Dear all, thanks for your contributions. I will try and check out those references.
Cheers,
Michujo.
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
flow modeling and incompressible analysis of internal flow of effervescent injector umar959 FLUENT 0 November 15, 2011 03:32
Boundary Conditions for Incompressible Flow Bob FLUENT 0 April 7, 2006 21:28
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
