Aerodynamic Moment at the Leading Edge
Old   September 28, 2012, 09:00
Default Aerodynamic Moment at the Leading Edge
Aerodynamics1 is on a distinguished road
I have two questions in hand, both related to Chapter 1 of Fundamental of Aerodynamics (Anderson).
In the process of deriving the moment around the leading edge, i.e. M'(LE), minus signs seems to be added in the x-dimension in dM'u and dM'l. I think it is related to sign convention depicted in Figure 1.20. But I cannot understand exactly how +/- sign is decided talking about the normal and axial forces acting on upper and lower body.
Moreover, in Figure 1.22, I cannot find an explanation why a triangle is drawn in that way (similar to the "4th quadrant in trigonometric graph"), to make sin(theta) a negative number?
Thanks for your answers!
Aerodynamics1 is offline   Reply With Quote
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 10:42
[DesignModeler] Creating a blunt trailing edge from collapsed leading edge gmd ANSYS Meshing & Geometry 0 March 2, 2012 09:48
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 08:11
