Kiva, Plots of mesh after generation
Old   March 16, 2006, 11:25
Default Kiva, Plots of mesh after generation
Sanaz
Hello everybody,
In K3PRE.f(the Preprocessor), in input file 'IPREP' there is a variable called 'PLOTMESH' which creates plots of mesh if its value set to be one.I set its value to one but I don't know how I can see its plots, does it require any other subroutine to convert it to tecplot file? or is it possible to see the plot of mesh by the file OTAPE17?
Thank you, Sanaz
Old   March 17, 2006, 06:03
Default Re: Kiva, Plots of mesh after generation
Ravi Kiran
Hi Sanaz
u can use general mesh viewer tool for post processing of a kiva simulation
ensight is also a tool for kiva post processing
for using kpost i.e. a default post processor u need to define priorly before kiva simulation the plane which u want and run kiva
bye Ravi Kiran
Old   March 17, 2006, 16:38
sanaz
Thank you so much for your help Ravi,
Old   March 19, 2006, 11:27
anand
Hi
as ravi kiran told you can use GMV ( general mesh viewer) or ENSIGHT for post processing. I feel ENSIGHT got more features than GMV. GMV is a freeware available at Losalmos official website.
you should translate otape9 data file to ENSIGHT format ( case file)
you can download fortran code for translating otape9 to ensight using this link
http://www.tfd.chalmers.se/~nordin/kivaReader.html
all the best
Anand
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
mesh converter in KIVA 4 DaIN Main CFD Forum 0 June 7, 2010 12:54
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
