does sombody know the cpu "PA-RISC 8500"
Old   March 21, 2006, 06:41
Default does sombody know the cpu "PA-RISC 8500"
ztdep
Hi: My research group want to by a HP workstation for the parallel computation, but i have noted that the workstation have 4 cpu, but the frequency of the cpu is only 440 Mhz, it is so slow. My desktop pc's frequency has reached 3G. What is the true meaning of the 440Mhz. Regards
Old   March 21, 2006, 06:59
Default Re: does sombody know the cpu "PA-RISC 8500"
ulwa
You can't compare the clock frequency for x86-processors with clock frequency of RISC processors. Take a look at a benchmark test of the programs you intend to run on the workstation instead.
Old   March 21, 2006, 07:37
William Blake
The "PA-RISC 8500" is much slower than a normal PC from today. So forget this.
Old   March 21, 2006, 08:49
ag
If you go to www.aceshardware.com you can find a whole host of SPEC benchmarks for most processors out today. The SPEC results for that processor show it to be far behind most of the x86 processors you can get currently. But make sure you compare apples to apples - multi-processor platforms to multi-processor platforms.
Old   March 21, 2006, 09:37
Steve
But the HP-UX OS has been 64-bit since 11.00, which allows pre- & post-processing of large models. Cheap, fast 64-bit computing has only really been available since the advent of Opteron/Linux systems. Win64 is far too new to trust.
Old   March 21, 2006, 10:23
William Blake
64 bit linux is available and works. Why do you want a very slow 4 processor machine for pre and post. You need a fast single processor machine there.
I would guess that using 4x PA-8500 processors with linear speedup is comparable to one PC processor.
Old   March 21, 2006, 12:20
Steve
"64 bit linux is available and works"
That's what I said. But it's only been the last few years. Before that cheap, fast Linux boxes were only used for parallel solving, requiring expensive (non-Linux) 64-bit boxes for pre and post. Mindsets take a while to change. Besides, getting graphical codes to reliably work on the multitude of Linux distro's available is not the easiest task.
stop when I run in parallel Nolwenn OpenFOAM 36 March 21, 2021 04:56
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 05:26
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
Dual Core CPU hjasak OpenFOAM Running, Solving & CFD 5 July 22, 2006 03:57
