Global mass conservation in pipe flow
Old   December 26, 2012, 02:29
Default Global mass conservation in pipe flow
qrie is on a distinguished road
I am simulating flow through a pipe. In my code, as is usual - I have a factor(ratio of mass in/mass out) multiplying the exit velocity for global mass conservation.
At the inlet I have given a parabolic velocity profile and convective outflow bcs at the outlet. So now when the factor is calculated for the first time step, it becomes infinity(since mass out is zero at the exit boundary) and the whole thing blows up.
How to resolve this?
Thanks,
Qrie
qrie is offline   Reply With Quote
Old   December 27, 2012, 03:58
Rami Ben-Zvi
Rami is on a distinguished road
Originally Posted by qrie View Post
Thanks,
Qrie
Hi Qrie,
I don't think this trick is common, and it is actually unnecessary. If your code is properly written, the mass balance should be nearly perfect, especially for a pipe flow.
Good luck,
Rami
Rami is offline   Reply With Quote
Old   December 27, 2012, 17:47
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
Yep, correction is unnecessary. If you really want to do this, however, just set limits for the max/min factor that you want to apply so it never gets too big or small because this will be much worse than allowing a mass imbalance. In the early iterations it really doesn't matter if there is a mass imbalance because the code should sort it out on its own as it converges.
cdegroot is offline   Reply With Quote
global mass, mass conservation, pipe
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
