CFD's three pillars in math, computer science and mechanics |
Rep Power: 13 ![]() |
On wiki, it stated CFD's three pillars are in math, computer science and mechanics.
How true is that? |
cfdnewbie
Rep Power: 20 ![]() |
It is true ....what's the reason for your question??
cfdnewbie
you will need a solid education in fluid mechanics then, plus some good math skills. and don't be afraid to program, and learn C or Fortran. Good luck!
#5 | |
Isn't matlab conmonly used in CFD? You said C 'or' fortran. Is learning both better or would just one be enough? |
cfdnewbie
Matlab is a very useful tools for trying out new stuff in 1 (or max. 2) dimension, and it is nice to do quick visualizations and such. But it is no good for real 3D.
Matlab is a smal model turbine that lets you try out different configurations and learn the basics, but if you want to propel a fighter, you need a real engine ![]() Either Fortran or C is fine, research codes tend to be written in Fortran (exceptions exists, of course), while commercial codes are more C based. But the important thing is that you learn a real programming language suitable for HPC! |
#7 | |
Sorry, I forgot to check back. I am planning on doing research in CFD for grad school. I saw that you stated Fortran is mainly used for research codes and C is mainly used for commercial codes. From what I understand, research in CFD is revolves more around generating the code rather than a pre-generated (commercial?) code's application Is knowledge of both languages (Fortran and C) necessary? Or is knowing one of the 2 sufficient for research based projects? A professor at a lab I want to work at says they use Fortran and C, but I'm not sure if that implies both or one of the 2. Thank you! |
cfdnewbie
One language should be sufficient, once you understand the concept of procedural programming, you should be fine. I prefer Fortran, but that's just a personal opinion.
#9 | |
Would it take long to learn C++ if you already know C? In a class I'm taking this semester, they will be teaching some language called PICBasic. I'm not sure how similar this is to BASIC. I heard Fortran should take too long to learn if you know BASIC. |
