Impermeable Wall BC Euler Equations
Old   January 31, 2013, 12:32
Default Impermeable Wall BC Euler Equations
Christian87 is on a distinguished road
as the title says I tried to implement an impermeable wall for my 2D Euler equiation Richtmyer FV solver. For validation purposes I'm currently doing calculations for easy cases like the wedge (see pic).
This wedge has an angle of 20° and the freestream Mach number is 3.3. According to the analytical solution (dotted line) there should be a Mach number of 2.75 downstream of the shock.
Unfortunately, I get a Mach number of around 2.3 and I'm blaming my wall bc since the grid should be fine (see pic). If you wonder why I approximated the apex by a parabola, it's only to exclude errors induced by the singularity of the apex. My first grid had an even stronger deviation.
The bcs at the left side is supersonic, respectively supersonic outlet at the right side.
The variables on the wall (j=1) are obtained by extrapolation of the values of the interior
q1bc=q1(i,j+1)
q4bc=q4(i,j+1)
q2bc=q2(i,j+1)
q3bc=q3(i,j+1)
In the next step I transfrom the velocity by using the tangential vector, which I obtain by
t=[x(i+1,j=1)-x(i-1,j=1);y(i+1,j=1)-y(i-1,j=1)];
taking the neighbour wall nodes. After that I norm t and calculate the wall velocity with the dot product (*) as
u_w = (t*[q2bc ; q3bc ]) t
and finally obtain my values for
q2bc=uw(1,1) and q3bc=uw(2,1).
This gave me good results for the Laval nozzle but here for the wedge I think this is the only potential source for the deviation.
Any hints or advice is strongly appreciated. Thank you for reading.
Christian
Christian87 is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Delta form of Heat, Euler and NS equations RameshK Main CFD Forum 3 May 30, 2012 10:41
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
